July 1, 2013, 08:57 |
Solution changing with dt.
Rep Power: 15 |
I have a code in cylindrical coordinates that uses central differences. My problem is this: when I change the time step size, keeping everything else the same(grid included), I get vastly differing solutions. Been breaking my head over this - any ideas?? Thanks in advance! |
July 1, 2013, 11:21 |
cfdnewbie
Rep Power: 20 |
Are you talking about a steasy state problem or an unsteady one?
July 2, 2013, 01:01 |
Rep Power: 15 |
Its a steady state problem.
July 2, 2013, 03:18 |
cfdnewbie
Rep Power: 20 |
Are you using an implicit or explicit solver for this?
July 2, 2013, 04:25 |
Rep Power: 15 |
Advection terms are explicitly calculated. Viscous terms in the radial direction alone are implicitly calculated.
July 2, 2013, 05:09 |
Filippo Maria Denaro
Rep Power: 71 |
I think that the discussion of your problem must be better focused:
- what variable you see that strongly change with dt? - what about the cell Re number? are you sure to fulfill the stability constraint? - have you experienced the same behavior for refined h steps? |
dt size |
Integrated conjugate heat transfer solver in OpenFOAM | hjasak | OpenFOAM Running, Solving & CFD | 172 | April 13, 2023 00:42 |
Asymmetrical solution using RANS | Marli | FLUENT | 2 | January 9, 2015 09:26 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Mesh independent solution | CFX Begineer | CFX | 0 | October 27, 2002 10:54 |
Discussion about Mesh independant solution | Seb | Main CFD Forum | 13 | May 22, 2001 13:37 |
