STONE'S STRONGLY IMPLICIT SOLVER
Old   August 11, 2006, 16:10
Default STONE'S STRONGLY IMPLICIT SOLVER
anybody
ich habe eine Frage zum SIP. Bei Wikipedia wird der Algorithmus erklärt (http://en.wikipedia.org/wiki/Stone_method). Leider geht für mich aus der Beschreibung nicht hervor, wie die Matrix N bestimmt wird.
Ax = (M-N)x = (LU-N)x = b
Old   August 12, 2006, 08:10
Default Re: STONE'S STRONGLY IMPLICIT SOLVER
ztdep
what did you say!
Old   August 12, 2006, 08:47
anybody
I don't understand the SIP (http://en.wikipedia.org/wiki/Stone_method). One reason is, that there is no explanation what does N mean.
If A and b are known where is the reason to go on with an iterative process? The L-U-decompensation leads to the exact result....
Old   August 14, 2006, 05:27
Tom
"If A and b are known where is the reason to go on with an iterative process? The L-U-decompensation leads to the exact result...."
Because A is generally a very large (sparse) matrix whose LU factorization is dense => very large amount of memory to store ; e.g. if you have 1 million grid points then in double precision you would reguire around 7450Gb of RAM just to store the complete LU factoriztion. For a Laplacian type stencil (7 nonzero entries per row in A) then the ILU will only require around 54Mb (and significantly less if the matrix entries are constant)*. Also, in gerneral, the number of floating point operations will be lower for a suitably accelerated iterative scheme with a good initial guess compared to the full LU (assuming you could store it).
(*) SIP will actually require the full 54Mb even when the entries of A are constant unlike ILU due to extra interpolations performed in SIP.
NOTE: SIP only works for matrices (A) obtained via a discretization of a PDE unlike ILU.
Old   August 16, 2006, 14:22
anyone
"Because A is generally a very large (sparse) matrix whose LU factorization is dense => very large amount of memory to store ; e.g. if you have 1 million grid points then in double precision you would reguire around 7450Gb of RAM just to store the complete LU factoriztion. For a Laplacian type stencil (7 nonzero entries per row in A) then the ILU will only require around 54Mb (and significantly less if the matrix entries are constant)*. Also, in gerneral, the number of floating point operations will be lower for a suitably accelerated iterative scheme with a good initial guess compared to the full LU (assuming you could store it)."
I know that A is a sparse matrix. I thought the L-U algorithm could be used in this way:
A*u = r and A=L*U
L*q = r --> U*u=q (forward/backward substitution)
This would lead to the exact solution u if the right hand side q and A are known. I cannot see why iterations would be necessary...
How did you calculate the required mem for 1.000.000 grid points?
Thx.
Old   August 17, 2006, 03:20
Karsten
As you have already written: Ax = (M-N)x = (LU-N)x = b
so A=(LU-N) and not A=LU ,
LU is not the complete LU decomposition, meaning it has only nonzero elements where A has nonzero elements. It is sparse, while the full LU decomposition wouldn't be so sparse. The other elements are stored in the matrix N which of course could be calculated by N=LU-A. This decomposition is used in iterative methods: Mx = Nx + b can be solved iteratively by: M x_i+1 = N x_i + b or x_i+1 = M^(-1) N x_i + M^(-1)b This is useful If M can easily be inverted, and M^(-1)N has specific properties (abs of largest eigenvalue <1).
Old   August 17, 2006, 06:19
Tom
"How did you calculate the required mem for 1.000.000 grid points?"
It's what would be required to store a full 10^6 x 10^6 matrix which you would have to consider doing if you formed the full LU factorization.
As an exercise write down the finite difference equations for the Laplace equation on a square with 10^2 and 25^2 points and form the LU factorization of the matrix and see how many zeroes there are and compare this to the original matrix which has just 5 bands.
Old   August 18, 2006, 09:40
anyone
Could you give an explicit example for N. I read several papers about the L-U-decompensation and I got mixed up with it. I got the impression the word L-U-decompensation is interpreted in different ways.
[2.0 1.0 0.0 0.0 0.0 0.0 0.0]*****[1.0 0.0 0.0 0.0 0.0 0.0 0.0]*****[2.0 1.0 0.0 0.0 0.0 0.0 0.0] [1.0 2.0 1.0 0.0 0.0 0.0 0.0]***** [0.5 1.0 0.0 0.0 0.0 0.0 0.0]***** [0.0 1.5 1.0 0.0 0.0 0.0 0.0] [0.0 1.0 2.0 1.0 0.0 0.0 0.0]*****[0.0 0.667 1 0.0 0.0 0.0 0.0]*****[0.0 0.0 1.3 1.0 0.0 0.0 0.0] [0.0 0.0 1.0 2.0 1.0 0.0 0.0]**=**[0.0 0.0 0.749 1 0.0 0.0 0.0]*****[0.0 0.0 0.0 1.25 1 0.0 0.0] [0.0 0.0 0.0 1.0 2.0 1.0 0.0]*****[0.0 0.0 0.0 0.8 1.0 0.0 0.0]*****[0.0 0.0 0.0 0.0 1.2 1.0 0.0] [0.0 0.0 0.0 0.0 1.0 2.0 1.0]*****[0.0 0.0 0.0 0.0 0.833 1 0.0]*****[0.0 0.0 0.0 0.0 0.0 1.166 1] [0.0 0.0 0.0 0.0 0.0 1.0 2.0]*****[0.0 0.0 0.0 0.0 0.0 0.857 1]*****[0.0 0.0 0.0 0.0 0.0 0.0 1.14] *****A*****=**********L*********************U One paper calls this a L-U-decompensation....which would not be right with your definition!
I think I understood, why it makes sense to solve the system of equations iteratively. Using SIPSOL for non-linear equation systems means that A is not constant because the coefficients include mass-fluxes (rho*u)!
Old   August 18, 2006, 10:01
Tom
The LU in SIP is not the LU decomposition it is the Incomplete LU (or ILU see the book by Peric & Ferziger for an explanation). The full LU has N=0 but because ILU is not the complete factorization there is an error (N = LU-A is nonzero).
Implicit solver for gamma volumefraction equation sek OpenFOAM Running, Solving & CFD 38 July 11, 2015 04:59
Implicit Euler Solver felixrieper OpenFOAM Running, Solving & CFD 0 May 18, 2006 07:19
Convergence with coupled implicit solver Henrik Ström FLUENT 1 October 29, 2005 03:57
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
FD NS implicit solver N.SUBRAMANIAN Main CFD Forum 6 August 20, 2000 22:24
