Density- vs. Pressure-Based Solvers
Like Tree2Likes
  • 1 Post By Dwayne
  • 1 Post By Dwayne
Old   July 5, 2013, 13:05
Default Density- vs. Pressure-Based Solvers
Dwayne is on a distinguished road
Hey Guys,
I know the difference between density-based and pressure-based flow solvers and I know their extensions to regimes of arbitrary Machnumbers. So preconditioning and density-velocity-pressure-coupling.
My question is how I decide wich solver I should use in what situation. What are the advantages and disadvantages of both? I only found out that density-based solvers are better in solving shocks.
Thanks for help!
immortality likes this.
Dwayne is offline   Reply With Quote
Old   July 7, 2013, 04:07
immortality's Avatar
Ehsan
immortality is on a distinguished road
there may be not a clear boundary between them.
Density based solvers are originated for high velocity flows,although pressure based have improved a lot for high velocities too but still density based's are better in mach around ond and higher,i think it depends on the problem if others add something is nice.
I'd like to know preconditioning if you tell me a bit.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   July 7, 2013, 06:51
Thanks, in compressible flows information is carried with flow velocity and also with speed of sound. So you have to consider both velocities is your stability consideration. For explicit methods the CFL-Condition must be fulfilled wich causes very small timesteps because of the high speed of sound.
A system is than called bad conditioned. In other words: A system is bad conditioned because of the large disparity of the eigenvalues of the jacobian. By multiplying the timederivation with an preconditioning-matrix you can force the eigenvalues to be of similiar order. This also solves the accuracy problem of density based solvers at low mach numbers.
Old   July 7, 2013, 08:13
Ehsan
thanks,may multiplying a matrix to time derivation cause an inaccuracy in each time step in real unsteady problems?
and what nSweep is better in your opinion?
Old   July 7, 2013, 08:53
That's right the preconditioned equations have only the stationary solution in common with the orginal equations. But the time accuracy can be restored by dual time stepping. I just found out that this is really time consuming so this is an disadvantage of preconditioned density-based solvers. Thanks for the hint.
What do you mean with nsweeps? Density-based solvers don't need iterative methods I thought or am I wrong?
density based, preconditioning, pressure based
Strange residuals of the Density Based Solver Pat84 FLUENT 0 October 22, 2012 15:59
pressure correction scheme vs density based scheme PCFD Main CFD Forum 0 May 18, 2009 15:57
Pressure vs. Density based jan FLUENT 2 May 3, 2007 03:45
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 11:26
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
