July 21, 2013, 12:40 |
IC Engine analysis
Robert Gonçalves
Rep Power: 12 |
Hello! I hope I am posting this in the correct location. I would really thank a little bit of help, since I have been having some difficulties in this matter.
I intend to do a CFD analysis of an IC Engine for my masters thesis. I have two big doubts about the construction of the model: 1) I intend to create the model in CATIA, mesh it in Pointwise and analyze it in Fluent. Of my knowledge, Fluent can recognize a solid body as a fluid. Therefore, should i construct the model as a solid, or is there another way more recomendable? 2) My other question is the valves. Also, how should I introduce the valves in the body? Create a diferent part, or should i create it within the same body as the cylinder? Thank you for your time! |
July 22, 2013, 16:15 |
#2 | |
Hope this helps. |
July 22, 2013, 16:18 |
Robert Gonçalves
Rep Power: 12 |
Hi! Thank you for your answer! So you mean I should use the surface design and not the part design correct? I will give it a try and then give you some feedback! Thank you very much!
July 22, 2013, 16:23 |
Robert Gonçalves
Rep Power: 12 |
I forgot to ask something.. I am drawing just half of the cylinder. Do i need to put a surface on the symmetric face? Thank you for your time!
catia, fluent, ic engine, pointwise |
Display Modes | |
Combustion analysis of diesel engine | unsolver | Main CFD Forum | 0 | October 13, 2012 06:15 |
Need help for IC engine analysis in basic level | tsram90 | FLUENT | 0 | November 3, 2011 06:57 |
ic engine in-cylinder gas flow analysis | george thomas | CFX | 5 | January 29, 2008 07:49 |
engine flow analysis to find torque | maurizio | CFX | 8 | August 13, 2007 02:07 |
Coolant flow analysis - IC engine | Frank | FLUENT | 2 | May 19, 2002 15:59 |
