SSIIM2: constant continuity residual
Old   July 25, 2013, 05:24
Default SSIIM2: constant continuity residual
Miss Mummputz
Mummputz is on a distinguished road
Hi!
I have more or less the same problem as student2008 in the thread
http://www.cfd-online.com/Forums/flu...ous-media.html
and can't solve it: I am simulating a straight river over a chute with SSIIM2. While all residuals become very small after some time, the continuity residual first oscillates and than stabilizes at a constant value (namely 52.2).
The sum of all the water inflow and outflow in the geometry is very low.
first I tried to lower the relaxation factors, however, this did not help anything.
in student 2008's thread people are talking about local scaling, so I scaled the residual taking the largest absolute value in the first five iterations as denominator (following the instructions described on
http://jullio.pe.kr/fluent6.1/help/h...def-resid-eq3a
)- however, the maximum value in the first five iterations is not very high and my scaled residual reaches a value of 0.5 which is not very good neither....
furthermore: why taking the largest number in the first five iterations? is this just some random presumption??
as my understanding of cfd does not reach very far, I would be pleased if you could tell me a possible reason why my residual stabilizes (???)
attached I send you a graph of my residuals
thank you so much!
Mummputz
Mummputz is offline   Reply With Quote
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 08:35
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
