Applying Loads to Part of a Surface/spliting a part in ANSYS
Like Tree1Likes
  • 1 Post By 123catty456
Old   July 18, 2013, 06:56
Default Applying Loads to Part of a Surface/spliting a part in ANSYS
123catty456 is on a distinguished road
I am looking to apply loads and constraints on a part, but not over its entire surface;
I am looking to simulate holding a pipe as such but clamping it a certain distance from one end (will be applying a force to something sticking out of the other end)
I thought if in Pro E I just created a separate surface that I could apply the load to that but I cant select it in Ansys mechanical.
I thought also if I created a new coordinate system for this surface but I seem to only be able to create a point; is it possible to split the part in Ansys to apply the frictionless support to only a certain section of the overall part or must I split it in Pro E and bring it in as an assembly?
All answers really appreciated!
thank you
M_H215 likes this.
123catty456 is offline   Reply With Quote
Old   July 29, 2013, 13:52
sooo yea... !!thought I would reply if anyone has this issue; ended up doing just that; had to split the part in proE and assemble it inorder to apply the constraints to only part of the surface; just gave it a "bonded" contact between the parts that were actually meant to be one part. this could be done in Design modeler but I dont have a licence for that.
loads over separate areas, splitting part in ansys
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 s.mishra ANSYS 0 March 31, 2012 05:12
how to use CFX result/mesh in Ansys adam2008 ANSYS 0 March 29, 2011 11:48
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! Cirion0000 CFX 0 July 6, 2009 15:26
Any other way of converting a multi part to a single part avoiding ANSYS Design Model LusoMundo ANSYS Meshing & Geometry 1 May 14, 2009 15:35
CFX transition to being part of Ansys CFXQuestion CFX 12 September 8, 2003 10:00
