August 8, 2013, 06:37 |
computing boundary layer thickness
Liam
Rep Power: 12 |
Hi people,
Anyone knows how can I compute boundary layer thickness for an arbitrary geometry? I have seen some theoretical formulas for flat plates, but I am not sure if there exists a formula for any kind of problem... Thank you so much |
August 12, 2013, 06:29 |
Fateme Sh
Rep Power: 12 |
first you need to find the first row height
regarding to your flow condition you can find your first row height with the help of yplus calculations in here: http://geolab.larc.nasa.gov/APPS/YPlus/ then i think 12 rows is enough (base on my experiments and studies) for the boundary layer mesh |
August 12, 2013, 06:47 |
Liam
Rep Power: 12 |
Hi aeroAngel,
I am seeing that those calculations are for a flat plate. Are the values computed here valid for an arbitrary geometry? Thanks for your reply! |
August 12, 2013, 07:24 |
Fateme Sh
Rep Power: 12 |
the nasa calculator is based on yplus calculations which is for any wall-bounded flow,
I've used it in my calculations for any shape ,like other engineers that i know and I haven't seen something about not using it in my studies. I asked other engineers and they agreed |
August 12, 2013, 09:22 |
James
Rep Power: 12 |
Thank you so much! I will have to make several aproximations because freestream velocity is not given, I only know pressure values at inlet/outlet and I guess this info is not enough for the calculator...
August 12, 2013, 09:32 |
#6 | |
Rep Power: 12 |
After solving your case with the mesh corresponding to your assumption, you could use the solution to improve your reference velocity, in order to adapt your mesh to the physics of your case. |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Questions about Boundary Layer Thickness and Turbulence Models | famerfamer | STAR-CCM+ | 3 | July 12, 2012 09:47 |
Boundary Layer roughness/ low reynolds wall treatment | Luigi_ | STAR-CCM+ | 1 | March 14, 2012 08:40 |
Boundary Layer Flow Paradox | Wen Long | Main CFD Forum | 3 | September 24, 2002 08:47 |
boundary layer thickness | 98.4F | Main CFD Forum | 1 | December 29, 2000 07:23 |
