August 18, 2013, 10:14 |
turbulent or laminar flow
Rep Power: 12 |
I model flow through a triangular duct. At the inlet of the domain the flow seems to be turbulent with Re=4600. At the outlet the Re is decreased to 900, because of increasing cross-section. In my opinion relaminarization takes place. Am I right? In addition to the SSt-Model I used the transition model. Both methods give similar results for pressure drop and other quantities, that I am interested in. Is there any way to determine exactly wether a flow is turbulent or laminar (comparable quantities for sst and transition model)? I used the eddy viscosity ratio to compare both approaches. But a maximum value of 46 seems realy too less for turbulent flow to me, isn't it? What model should I use? thanks in advance |
August 18, 2013, 11:12 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
August 18, 2013, 11:38 |
Rep Power: 12 |
thank you for your quick reply. Yes, there is an increasing area. But how can the flow still be turbulent with Re=900? Kind regards |
August 22, 2013, 10:43 |
Hamid Zoka
Rep Power: 18 |
I think a positive pressure gradient (if it is high enough) can lead to relaminarization process. Moreover, flow separation is not necessarily an indication of turbulence. Separation can happen in laminar flows as well. But, in your case you can check the shape of velocity profile at near wall regions. Laminar and turbulent flows have distinct velocity profiles. Another point is that since you have a separated flow, shear stresses between main stream and circulating flow increase and may produce turbulence. so you can check K and epsilon (or turbulent viscosity) at these regions. |
August 22, 2013, 11:50 |
Rep Power: 71 |
These can be of some help
http://arxiv.org/pdf/physics/0409037.pdf http://arxiv.org/pdf/1307.7965v1.pdf |
August 24, 2013, 05:33 |
Rep Power: 12 |
thank you very much. These Information help a lot. I had a look at the eddy viscosity ratio and I think the flow is still turbulent. |
Do formula for Laminar and Turbulent Flow Calculation formulae change with Fluid | Parag Gadgil | FLUENT | 0 | June 19, 2012 07:07 |
Turbulent / laminar flow | broken | Main CFD Forum | 0 | May 9, 2012 06:44 |
Can I use turbulent model to solve a laminar flow? | nikhil | FLUENT | 5 | February 1, 2011 10:42 |
Turbulent viscosity in Laminar Flow | Mike | Main CFD Forum | 8 | April 12, 2010 11:40 |
Reynolds and Turbulent flow | Frederic Dubinski | CFX | 5 | October 21, 2004 04:12 |
