A simple System Coupling Application stubbornly unconverging |
January 29, 2021, 06:59 |
dyon
Rep Power: 5 |
I am trying to simulate a rubber ring that pulsates in water and the solution does not converge at all.
The ring is modelled in Transient Structural and expands/shrinks once in every 4s (so very low frequency). Any idea what might I be doing wrongly ? I can provide you with any detail/screenshot/animation you may need to figure out how to help me. Many Thanks ! |
January 29, 2021, 09:45 |
Kira
Rep Power: 8 |
You could go over this FAQ and see if you can implement some of the things they suggest: https://www.cfd-online.com/Wiki/Ansy...gence_criteria If nothing there works, you can report what you tried and we can try to help after. |
January 29, 2021, 14:25 |
#3 | |
andy
Rep Power: 17 |
What do you mean by not converge at all? The errors in the solved equations remain high, the flow doesn't settle down to a harmonically repeating one, or something else? |
January 30, 2021, 03:10 |
#4 | |
dyon
Rep Power: 5 |
It is a time varying simulation, the ring pulsates (expands/contracts see Screenshots) due to time varying pressure inside. The ring is modelled and setup in Transient Structural (see PressureSetup screenshot attached). The ring pulsates in water. The water is modelled as a cube in Transient Structural. The Geometry is shared with Fluent, where it is meshed and setup (see mesh in Fluent FluidMesh screenshot attached). Fluent setup: Transient / Inviscid / Pressure-outlet (for all the 6 faces of the cube / System coupling in Dynamic mesh at the common face water-ring / Smoothing (Diffusion) + Remeshing / Timestep size 0.1 s for 40 timesteps. Maximum iterations set at 10 in the System coupling (time step again 0.1 s) On running this, the first timestep (0.1 s) never converges (I have done even 50 iterations on it). Timesteps 0.2 s to 0.5 s converge (Y), time step 0.6 s does not converge (N), 0.7 s to 1.3 s (Y), 1.4 s to 2.2 s (N), 2.3 s to 2.5 s (Y), 2.6 s (N), 2.7 s to 3.5 s (Y), 3.6 s (N), 3.7 s to 4.0 s (Y). I have observed that continuity does not converge, more than velocities. I would appreciate your advice. I can provide more details if needed. Thank you vey much ! |
February 2, 2021, 15:51 |
#5 | |
andy
Rep Power: 17 |
If the fluid is incompressible and the external box is impermeable then you have defined a problem that cannot be solved. Is this the case? For an incompressible fluid the expansion/contraction of the ring must be balanced by an equivalent small amount of incompressible fluid flowing back and forth across the external boundary somewhere. It only needs to be, say, one side and since the flow will be tiny it won't affect the flow around the ring. Alternatively you could move one of the sides slightly so that the trapped fluid was of constant volume. Numerically what is going wrong is that the source terms in the Poisson equation are not summing to exactly zero. This is a requirement because although the determinant of the equation is zero if the sources sum to zero a pressure field can be determined to within a constant. If they don't then the equation simply has no solution. |
February 3, 2021, 11:58 |
#6 | |
dyon
Rep Power: 5 |
The fluid is incompressible, but I defined the 6 faces of the box (fluid) as pressure outlets (see screenshot). The case is with pressure-outlets and recognized as such by Fluent after hybrid initialization. In CFD post I can see velocities at the boundary pointing forwards and backwards. I think that pressure-outlets are considered permeable by the solver. |
February 3, 2021, 18:21 |
#7 | |
andy
Rep Power: 17 |
Every time step must converge or else the solution in time is meaningless. I am not familiar with Fluent's time stepping scheme but non-convergence on the first time step may be due to your initial conditions not satisfying continuity which they must. Is the ring moving at t=0 and the external boundary at rest at t=0? If so, this is an invalid initial condition. If you have an intial condition that satisfies continuity, a time step that is comfortable with respect to CFL and diffusion number limits and taking a very large number of iterations on the pressure equation doesn't drive the continuity error into roundoff then your current pressure boundary condition is likely unusable. The simplest boundary condition would be to specify a tiny constant in space normal velocity on the external boundary that changes through time to exactly balance the mass added or subtracted by the moving ring. I would expect Fluent to supply such a boundary condition because it is a simple and robust condition for testing moving grids. However, the screen dump of your pressure condition seems to show a whole bunch of options and so it may not be directly labelled as such. |
February 4, 2021, 07:44 |
#8 | |
dyon
Rep Power: 5 |
ansys; |
Display Modes | |
FSI system coupling problem | asoltoon | ANSYS | 1 | October 25, 2018 09:38 |
2-Way FSI Coupling Error (Oscillating Plate Tutorial) | EmiS | ANSYS | 2 | June 29, 2018 09:09 |
Ansys Licence Serve on Ubuntu 16.04 LTS | david.pasquale | ANSYS | 2 | January 20, 2017 11:52 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
