Rotating geometries; approaches in CFD
Old   October 12, 2006, 08:58
Default Rotating geometries; approaches in CFD
chuck
as far as I'm concerned rotating geometries are a very difficult problem in CFD because of the high mesh deformation. But what are the most common methods when we have rotating geometries such as impellers and so on?
Have a nice day!
Chuck
Old   October 12, 2006, 10:03
Default Re: Rotating geometries; approaches in CFD
sam
these are MRF and mixing plane
Old   October 12, 2006, 10:08
chuck
Thanks sam. No I have sth. I can search for!
Old   October 12, 2006, 10:33
chuck
typo: I wanted to write "Now I have sth. I can search for!"
Old   October 12, 2006, 11:10
sam
ok search more for mixing plane and its development and let me know wat u understood then we can discuss a bit more
Old   October 12, 2006, 12:48
chuck
Do you know any book or paper on this issue? It is very hard to find information on "mixing plane" or MRF via google. I can only find documents where there is said that a certain method was used, but without explanation.
Old   October 12, 2006, 13:04
Ben
try rotating reference frame or similar but MRF is not the best approach to rotating geometries, its fairly good for easy quick results but is not as accurate as proper moving mesh. A better approach is to use either a sliding moving mesh or a deforming mesh where the connectivity at the rotating interface. This way the cells are re-defined as the mesh slides.
Old   October 12, 2006, 13:05
Ben
http://www.cd-adapco.com/press_room/...cs/23/mrf.html try that.....
Old   October 12, 2006, 15:58
boling2002
Besides the sliding mesh, one thing you can try is overset(chimera) grid.
Old   October 13, 2006, 09:24
chuck
Hello, is mixing plane the same as sliding mesh?
Old   October 13, 2006, 11:40
  #11
sam
no.
Old   October 14, 2006, 09:51
  #12
dingxi
They are totally different, I think
Old   October 14, 2006, 09:54
  #13
dingxi
For simulation of turbomachinery flow field with a stator and rotor, is there any chance to use sliding mesh or overset grid if the steady flow governing equations are to be solved?
rotating equipment CFD recommendation Prospective User FLUENT 1 December 4, 2003 11:12
rotating equipment CFD recommendation Prospective User CFX 2 December 3, 2003 05:58
CFD for fans & blower housings David Carroll Main CFD Forum 8 August 24, 2000 17:25
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 August 21, 2000 04:49
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 11:44
