No conjugate heat transfer between solid (cast iron) and fluid (water) |
August 21, 2018, 21:00 |
Taiwan,new north city
Rep Power: 8 |
Hello guys,
I am working on conjugate heat transfer problem in fluent. In my problem i have one solid zone (cast iron) and one fluid zone (water). cold water flowing inside to the solid part (like water flowing in a pipe). water is used to cool the solid part. I have created coupled interface (wall and wall shadow) between solid and fluid zone. The solution converged but there is no conjugate heat transfer occurs. I tried this problem many time with all possible way. please help me with this. Boundary condition: water inlet velocity = 2 m/s water inlet temp = 303K outlet pressure = 2.5bar solid part temperature = 453K (I dont have h and heat flux value) Questions: 1. how to set thermal boundary condition if i only know solid temperature? 2. solution converged but no conjugate heat transfer taking place? Thanks in advance...Its urgent please help me with this guys. |
August 23, 2018, 13:01 |
Lucky
Rep Power: 65 |
The thermal boundary condition at wall and wall shadow should be coupled and not a temperature or heat flux. The momentum BC is no-slip.
No conjugate heat transfer between solid (cast iron) and fluid (water) part | Rajaero | FLUENT | 5 | June 25, 2023 03:07 |
solidification of cast iron 2 | Pukmester | FLUENT | 0 | July 15, 2015 07:03 |
Conjugate heat transfer | skarp | CFX | 2 | March 27, 2008 20:47 |
