Transient features in steady state simulation?
Old   October 9, 2013, 09:52
Question Transient features in steady state simulation?
Adhikar Hariram
PedFr0 is on a distinguished road
Hi All
In the case simulating flow with unsteady features, such as vortex shedding, using steady state simulation, will the results such as drag and lift co-efficients be valid? Would they essentially be the overall averaged values of the simulation or will the simulation need to be run as transient in order to get valid results?
Your help is much appreciated
Regards
Adhikar
PedFr0 is offline   Reply With Quote
Old   October 9, 2013, 11:11
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by PedFr0 View Post
Hi All
Regards
Adhikar
If the case admits no steady solution, a steady solver would simply not converge because the residual has a physical meaning that is the time-dependent part that balances all the fluxes.
FMDenaro is offline   Reply With Quote
Old   October 9, 2013, 11:22
Adhikar Hariram
Hi Filippo
So essentially if I get residuals that aren't fluctuating, and eventually converge, then I have valid drag and lift coefficients? I am getting something along those lines however I also have a monitor for velocity in a point in space and this shows a fluctuating velocity with iterations, yet my drag and lift coefficient monitors seem to be converging to a constant value as well as my residuals.
In short, I am seeing only fluctuating velocities yet all my other monitors appear to be converging, thus are my drag and lift coefficients?
Thank you for your speedy response and any further help would be much appreciated.
Old   October 9, 2013, 11:37
Hi Filippo
If density, momentum, energy go to a steady state any other derived quantity will be steady (drag, lift). Generally, a non-steady state of the flow will produce oscillating residuals. When the residuals appear to converge toward a constant value that can not be considered numerically "zero" then I suspect some errors...
However, laminar or turbulent flow model will drive to different meaning of the steady state.
Old   October 9, 2013, 11:49
Adhikar Hariram
Thank you for your help, and from what I can gather I basically may need to run the simulation as transient in this case if I have constant residuals yet an unsteady flow. Maybe I can attach some images when the simulation is complete and you can provide some further knowledge. Many thanks for the help.
Old   October 9, 2013, 16:06
Joern Beilke
JBeilke is on a distinguished road
A converged solution does not at all mean, that you get a physically correct result. Refine your mesh and see if you still get the same behaviour. Refine it probably even more. Run it transient and compare the lift and drag again.
Apart from this there might be lots of other reasons why the physics does not correspond to the numerics very well.
JBeilke is offline   Reply With Quote
Old   October 9, 2013, 16:18
yes, I agree that reaching a numerically steady solution does not mean that is accurate and physically relevant, it only means that the discrete system admits a steady solution. However, it is worthwhile remarking that if the case is statistically steady (as for simulation of turbulence with RANS) refining the grid is not necessarily an assessment of the quality because the turbulence model overwhelms the truncation error.
Old   October 10, 2013, 05:55
Adhikar Hariram
Hi, and thank you for the help. Moving forward I will certainly try your suggestions and see if it makes a difference, starting with the transient solution though as I am under some pressure for a result and this seems the most obvious first step forward. Thus far the simulation has finally complete and I have attached an image of the monitors I have in place in the case that you may provide further insight.
Old   October 10, 2013, 05:56
Adhikar Hariram
If the image does does not display properly please right click it and open it in a new tab. Thanks
Old   October 10, 2013, 06:34
your residuals clearly show that the solution will not converge towards a steady state. But, as I don't know details of your flow problem, I can not say if that indicates an unsteady solution or something is simply wrong in your setting.
Old   October 10, 2013, 06:50
Adhikar Hariram
Hi
My simulation is of flow over a heliostat at an angle of 30 degrees at a reynolds number of around 3x10^6. Seeing as the geometry is essentially two large, inclined flat plates that are in-line with each other, I have a strong feeling that the solution must be unsteady based on all the information you have provided. This especially so due to unsteady phenomena being associated with these kind of geometries.
Thank you very much for your help, I think I can now move forward from this problem and simply have to deal with the turn-over time associated with transient simulation.
Old   October 10, 2013, 06:54
Hi
The pointwise solution is surely unsteady due to turbulence but the problem is to assess if your problem admits a statistically steady state to use RANS or has a statistically unsteady stato to use RANS. But, to tell the truth, I don't see a reason why you can not reach a statistical energy equilibrium and get a steady state ...the two plated are fixed not moving, right?
Old   October 10, 2013, 07:04
Adhikar Hariram
Yes that's correct, the two plates are fixed in space.
So would you suggest then to also run the simulation as transient and to take an average of the results obtained via the transient simulation and compare them to the steady state solution in order to check if they are statistically valid?
Old   October 10, 2013, 07:07
Adhikar Hariram
Thats the exact geometry, just to clear things up
Old   October 10, 2013, 07:09
yes, correct. Be careful to run first the URANS for a sufficient time to cancel the initial numerical transient, then storing a meaningful number of fields to perform the statistical averaging.
Old   October 10, 2013, 07:12
Ok, I think that this problem should be better solved by URANS/DES models ...
Old   October 10, 2013, 07:17
Adhikar Hariram
Alright, thank you for your help. I will move forward using the unsteady approach from now.
drag coefficients, lift, steady state, transient
Moddeling solid settlement in water tank steady state or transient? 88phil88 CFX 1 March 9, 2011 18:45
Steady state > Transient Willem FLUENT 1 June 24, 2008 11:18
steady state simulation timesteps amine CFX 4 March 17, 2008 10:29
Transient vs Steady State Adam CFX 1 April 12, 2007 11:34
About the difference between steady and unsteady problems Lisa Main CFD Forum 11 July 5, 2000 14:37
