[Help!] impeller torque calculation: pressure and viscous moments |
October 21, 2013, 06:52 |
Rick
Rep Power: 26 |
Hi all!
I simulated a vessel+impeller with multiple reference frame and I want to calculate the power needed to drive the impeller: as I know the power P is: P [Watt]=2*pigreco*N*Torque N=revolution per seconds (12 rpm) Torque in N*m Impeller axis rotation is Z and the vessel is centered in X,Y; the domain is in +Z. Impeller rotates counterclockwise. Rotating frame is all the cylinder zone, which rotates at 12 rpm, because impeller 007/impeller 007-shadow are very closed to the wall. Bottom conical zone is stationary zone. Vessel walls have absolute 0 rotational velocity. Impeller/impeller 007/impeller 007-shadow have relative velocity to adjacent fluid zone of 0. If I calculate the pressure and viscous moments (moment center: 0,0,0 moment axis 0,0,1) I have: Impeller zone (all in N*m) Pressure: -225 Viscous: +103 Total: -122 Impeller 007 zone (all in N*m) Pressure: -109 Viscous: -8 Total: -117 Impeller 007-shadow zone (all in N*m) Pressure: -107 Viscous: -8 Total: -115 So total moment is: -354 and P should be: P=abs(total moment)*N*2*pigreco=354*12/60*2*pigreco=445 W Is it right? What I don't understand is why in the impeller zone viscous moment has opposite sign in respect to pressure moment. Can anybody explain to me please? I'm attaching some pictures. Thank you Daniele |
March 27, 2014, 02:37 |
Pekka Pasanen
Did you ever figure this out? I'm having the same problem with my turbomachinery case, the pressure moment seems to be in the right direction but the viscous moment has opposite sign, which doesn't make any sense to me.
CFD-Post: Pressure and Viscous Drag on Isosurface | Shirock | CFX | 4 | June 4, 2012 01:02 |
how does Fluent calculate the pressure and viscous force ? | e30.lsb | FLUENT | 7 | June 27, 2011 21:31 |
how does Fluent calculate the pressure and viscous force vector? | Ralf Schmidt | FLUENT | 2 | May 17, 2010 15:49 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
How to obtain correct viscous pressure drag using CFX? | Ketut Utama | Main CFD Forum | 1 | January 25, 1999 05:05 |
