Transient spacial dependent heat source
Old   October 28, 2013, 11:00
Default Transient spacial dependent heat source
Kumudu
Kumudu is on a distinguished road
I am almost new to OpenFoam and I want to add a transient heat source to specified points on the Mesh. Actually, I am working on Ground Source heat pump simulation problem. I want to add a source term representing the U-tube in the ground. In this U-tube water is circulating and this loop extract heat from the soil where the U-tube is buried. So, I want to add a volumetric source term such that,
q=UA(Ts-Tf),
where, Ts is the temperature at the soil and Tf is fluid temperature. U is the overall heat transfer coefficient. This source term should coincide with the ground loop configurations. That is in the three dimensional computational domain, I have to find a points that is in a U-curve and add the above source term to the points in the U-curve.
How could I do that. I saw that Kathrin has gave Robin a somewhat related answer. Could you please help me in this.
Kumudu is offline   Reply With Quote
[swak4Foam] Problem with Transient Heat Source (using swak4Foam expression Source) ahmmedshakil OpenFOAM Community Contributions 12 January 22, 2015 04:38
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 10:59
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
