Which parallel solver is most suitable for my app?
Old   November 17, 2006, 09:23
Default Which parallel solver is most suitable for my app?
zonexo
hi,
i'm currently using NSPCG to solve for my poisson eqn. it's sequential and at times, it can blow up suddenly. i'm considering of changing to another solver. since the poisson eqn takes up the most amt of time, i presume it'll be better if i can use a parallel solver as well.
i've searched around and these are the ones which I've found:
1. petsc 2. pARMS 3. Aztec 4. sixpack (sequential?)
basically, i've obtained a matrix from the 2d poisson eqn and it needs to be solved.
i'm writing in fortran and for debugging and code writing, i'm using compaq visual fortran but for actual simulation, i used my university's unix/linux server. i'm also worried of using some solver since i'm also not sure how to pass C codes to fortran...
anyway, can someone recommend or comment on these solvers whether if they are suitable....
thank you very much
Old   November 17, 2006, 09:46
Default Re: Which parallel solver is most suitable for my
agg
I've used aztec. It has worked well for me. It is also easy t o couple it with your fortran solver.
different results between serial solver and parallel solver wlt_1985 FLUENT 11 October 12, 2018 08:23
Divergence detected when using parallel solver Phil FLUENT 3 May 9, 2008 08:17
MPP Parallel solver problem with 3.2! tomosada Siemens 4 August 12, 2004 13:49
direct parallel solver sylvain Main CFD Forum 2 June 25, 2001 07:56
3D PARALLEL SOLVER (MPI Lib) Saud Khashan Main CFD Forum 8 July 14, 1999 08:52
