October 29, 2013, 08:52 |
NACA aerofoils
Stuart
Rep Power: 25 |
The equation for 4-digit symmetrical NACA aerofoils (see http://en.wikipedia.org/wiki/NACA_airfoil) when plotted gives a blunt trailing edge. But images of these aerofoils all show sharp trailing edges. Are these aerofoils adjusted from the equation so that the trailing edge is sharp? Thanks |
October 29, 2013, 11:00 |
Naca 4 digits have blunt edges, but the difference is almost neligible
In wikipedia they also write: "Note that in this equation, at (x/c) = 1 (the trailing edge of the airfoil), the thickness is not quite zero. If a zero-thickness trailing edge is required, for example for computational work, one of the coefficients should be modified such that they sum to zero. Modifying the last coefficient (i.e. to -0.1036) will result in the smallest change to the overall shape of the airfoil." |
NACA profile coordinates | melwyn rego | Main CFD Forum | 4 | November 21, 2012 06:44 |
NACA 0018- NACA 0020- NACA 0024 profiles | ali8500 | CFX | 1 | March 21, 2012 16:45 |
Mismatched NACA profiles | xTamx420 | Main CFD Forum | 0 | July 7, 2011 10:11 |
Symmetric NACA Airfoil Lift and Drag Data | jrider22 | Main CFD Forum | 3 | April 15, 2010 04:59 |
Ansys CFX Vs. NACA Summary Report. Mismatch Result | Santiago Orrego. | CFX | 3 | February 5, 2007 12:05 |
