unsteady RANS-flow around cylinder
Old   December 4, 2006, 10:06
Default unsteady RANS-flow around cylinder
omierka
Hi there,
our finite element based flow solver was extended with high-reynolds k-epsilon model which was later modified with Chien's low-reynlods model. It was also succesfully tested on a benchmark problem of channel flow and backward facing step. My aim is to simulate flow around cylinder at Re=10000. I know, that there is a problem with Chien's model to predict separation and reattachment, for this reason the friction velocity has an alternative scale, which is widely used in CFD (u_tau=srt{sqrt(c_mu)*k}), but the behaviour of the flow is still not what the experiments predict, because the solution is oscillation free (i.e. no vortex shedding is present). Do You know, if Chien's model is usable or not in this case, and if not what kind of model should I use? In fact I do not think, that I have problems with the resolution of the mesh, because y+ varies around the cylinder in a range of 0.1-0.4.
thanks, otto
Thread Tools
Trackbacks are On
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 13:00
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
how to predict unsteady flow from case definition? Felix Main CFD Forum 6 August 28, 2007 16:40
flow around circular cylinder...plz help yousef FLUENT 4 March 28, 2006 11:01
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
