Effect of convergence criteria for pressure loop on computation time |
November 29, 2013, 16:09 |
mohamed ali
Rep Power: 12 |
Hi
I have a code for mhd problems which uses navier-stokes and a poisson type electrical potential equation.when i use pressure low pressure convergence criteria (1e-6) pressure loop(Gauss seidal iteration) is converging very fast but going to steady state very slowly and sometimes after some time stepping the residual not changing at all.But when i give very low pressure residual(1e-9) gauss seidal iteration takes a lot of time but reaching steady state fast.Total computation time is less for the later case. what i thought was the opposite. Any comments on why this happening? Thanks |
convergence, gauss-seidel, magnetohydrodynamic, mhd problem, pressure loop |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 09:48 |
Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 09:08 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
Time step size & convergence absolute criteria | yuitsang | FLUENT | 5 | April 15, 2013 04:27 |
convergence problem when use pisoFoam, LES for wind tunnel case | Forrest_Lei | OpenFOAM | 3 | July 19, 2011 06:00 |
