turbulent mixing
Old   December 9, 2006, 06:53
Default turbulent mixing
khan
Can someone pls give me instructions as how to solve turbulent mixing problem. I am given intial condition of Mach # of 2.0 and 3.0 above and below a plate. I have to model this in gambit and then solve using fluent. Can anybody provide me with some help.. Its urgent Thanks
Old   December 9, 2006, 15:55
Default Re: turbulent mixing
Andrew
So you're looking at a spatially developing mixing layer, at supersonic speeds? What kind of models are you going to be using in the flow solution, and what type of geometry will your mesh be based on?
Old   December 9, 2006, 18:04
khan
I have created a rectangular mesh of 120*100 grid size. top and bottom surface are symmetrical, inlet has two streams conditons I will be using standard k-epsilon model and rng k-epsilon model and then compare the result with analytical solution. I have created the mesh in gambit, but I do not know how to setup the problem in fluent. I mean how to generate contour of mixing layer.
Old   December 11, 2006, 04:33
Andrew
One can use a hyperbolic tangent function to specify the inflow condition for the layer, of the form
u(y) = 0.5(U1 - U2) + 0.5(U1 + U2)tanh(di/2)
where U1 and U2 are the freestream velocities of the high- and low-speed streams, and di is the initial vorticity thickness of the layer.
A RANS type solution may give reasonable results when compared to an analytical solution, but it will be unable to resolve the large-scale coherent strucutres known to be present in the shear layer flow at both subsonic and supersonic velocities.
Turbulent eddy diffusivity for mixing?? Ray Main CFD Forum 3 November 5, 2020 11:57
Turbulent Mixing Layers Kieran Hood Main CFD Forum 2 April 27, 2007 07:06
Prandtl Mixing length Vs. Isotropic turbulent Mohammad Kermani Main CFD Forum 0 March 23, 2000 23:06
LES unsteady : Turbulent Mixing Layer Flav FLUENT 5 December 13, 1999 03:11
turbulent mixing of two fluids ulrich bieder Main CFD Forum 2 October 9, 1999 16:15
