SSIIM- F 36 2: computation of the vertical water surface elevation |
March 19, 2013, 10:44 |
Miss Mummputz
Rep Power: 13 |
Dear all!
I have a channel with cross- bars where I'd like to use the F 36 2 function to compute the vertical elevation of the water surface with SSIIM 1. However, due to the cross- bars, this function is extremely unstable and diverges. I don't know how to stabilize it- do you have any idea?! I already tried to make a very fine mesh of straight rectangles- it didn't work.. The computation does work with the F 36 0 function, but is far too inexact and does not create the real water surface elevation which was measured in the pilot experiment. thanks a lot for your help!! |
July 1, 2015, 04:14 |
hani
Rep Power: 10 |
hi dear.
does your problem answerd? |
July 1, 2015, 04:52 |
hani
Rep Power: 10 |
hi dear.
do you active still in frume? does your problem answered? |
Spillway Analysis Fixed Water Surface Boundary Condition | mgdenno | OpenFOAM Running, Solving & CFD | 17 | December 9, 2018 17:37 |
SSIIM 2, vertical elevation of the water surface, transient water flow parameters | Mummputz | Main CFD Forum | 6 | November 18, 2012 13:39 |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 04:31 |
Gravity Flow Velocity Computation | Jerry McHugh | Main CFD Forum | 1 | March 16, 2007 13:24 |
Simulating Water Splash Using a Particle System | Zi-Wei Chiou | Main CFD Forum | 0 | March 4, 2002 06:33 |
