DES / URANS / SAS sampling for convergence study
Old   December 12, 2013, 08:19
Default DES / URANS / SAS sampling for convergence study
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Dear all,
I need some advice.
I want to simulate a pipe with a bluff-body in it (vortex flow-meter). Now, before comparing any result with measurements, I want to be sure my simulation is numerically robust / converged. For that, I would like to vary things such as the inlet length, outlet length, time-step, convergence criterion at each time-step, grid size, turbulence model (see title) ...
For each of them I am going to try if the solution changes significantly when I increase / decrease it.
The question is: What parameters should I watch? Since the simulation is highly unsteady, I can not just use some simple pictures. Also time averages will propably not be very usefull, because of the large vorticies. Maybe time averages of u'' / v'' / w'' ? Or an FFT the force on the bluff body?
Philipp.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   December 12, 2013, 10:05
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
The RMS value of the force on the bluff body (especially in cross-streamwise direction) would be another good indicator for convergence, at least for the URANS simulations.
The frequency of the vortex shedding is another good indicator since this is the variable a vortex flow meter actually measures.
Will you present some of the results here?
flotus1 is offline   Reply With Quote
Old   December 16, 2013, 04:46
Philipp
Alright, I will try that. Yes, it will take some time, but when I am done, I will show results here.
What is the best way to get the shedding frequency? Using an FFT seems to be not good, because I will need thousands of periods to get an accurate result. Do I just need to do this "by hand"?
Old   December 16, 2013, 09:14
flotus1's Avatar
Alex
For the URANS methods you can determine the shedding frequency by counting waves in the plot, yet I dont think it will be possible with DES and SAS.
But you dont really need that many periods to get a result. I doubt that the differences will be that small.
sampling interval and sampling frequency beauty FLUENT 13 November 9, 2022 08:23
How to use DES well? Daniel Main CFD Forum 0 October 26, 2008 05:59
DES ( SA+LES) vs DES ( kwSST+LES) for bluff body Phil Main CFD Forum 0 January 8, 2008 09:04
