Two-phase flow on porous media - Validation of 1D flow |
January 2, 2014, 02:05 |
Jhabriel Varela
Rep Power: 12 |
Hello, I'm having some problems validating a numerical simulation (ImPES [Implicit Pressure Explicit Saturation]) with the Buckley-Leverett (analytical) model. As you know, the Buckley-Leverett model only needs a constant inlet flow of a phase, on the other hand the ImPES method only deals with pressures values. How should I treat the boundary conditions in the ImPES method in order to compare the both cases?. I tried setting a fixed total Darcy velocity, but, in order to conservate the mass, in theory, the total velocity through each faces should be the same, so I would have the same velocity on all the time levels, and the saturation front won't be able to propagate.
Thanks for any idea. Jhabriel Varela National University of Asuncion jhabriel@gmail.com Last edited by jhabriel; January 2, 2014 at 04:53. |
buckley leveret equation, impes algorithm, porous media |
Display Modes | |
Problem on boundary conditions (multi-phase, porous media, 3 flow domains) | Juun | FLUENT | 1 | November 19, 2023 01:06 |
Multiphase Porous Media Flow - Convergence Issues | VT_Bromley | FLUENT | 7 | May 14, 2020 16:34 |
Flow through porous media: permeability issue | butterfly1 | Main CFD Forum | 1 | January 2, 2014 02:34 |
reg Porous two phase flow simulation | chittoorreddy | STAR-CCM+ | 1 | December 21, 2009 05:37 |
Can LES be used in porous media flow? | Jin | Main CFD Forum | 0 | October 19, 2006 08:50 |
