A question for 'Tom'
Old   February 6, 2007, 05:58
Default A question for 'Tom'
desA
Hi Tom,
Can I ask you to refresh your memory on a discussion we had around 1 year ago where we were discussing the possibility of shock waves in low-speed viscous flows.
You made a comment something along the lines of (paraphrased):
The diffusion eats up the characteristics.
In view of my current research, could I ask you to please elaborate in more detail on that point? My work in a 2D field shows that you were correct on that comment. Would you be able to describe the mechanism?
I've see a comment regarding solitons, where is was stated that the non-linear wave is prevented from breaking by the effect of the dispersion term. I'd like to try & get a minds-eye view of the physical mechanism that the diffusion uses in the N-S.
Thanks so much for your time.
desA
Unanswered question niklas OpenFOAM 2 July 31, 2013 16:03
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 15:26
Question about Table applicaiton. universez OpenFOAM Running, Solving & CFD 0 January 12, 2010 20:31
CHANNEL FLOW: a question and a request Carlos Main CFD Forum 4 August 23, 2002 05:55
question K.L.Huang Siemens 1 March 29, 2000 04:57
