August 22, 1998, 11:32 |
tetrahedral meshing Codes
Hi:
We have developed our own adaptive CFD-Code for explosion modeling. We use as a input a tetrahedral based unstructured mesh in 3-D and based on triangles in 2-D. In the 2-D I have used EASYMESH and TRIANGEL up to now. These codes are public domain and work well. In the 3-D case I have used GEOMPACK (also public domain), which only works well for simple geometries. Could anybody recommand a public domain code for tetrahedral meshing on non trivial geometries. The code should also be avalible out the USA. Thank you very much for your help. Ciao Heinz |
August 26, 1998, 14:03 |
Re: tetrahedral meshing Codes
NetGen is a 2/3D mesh generator using linear triangular/tetrahedral elements: http://nathan.numa.uni-linz.ac.at/netgen/usenetgen.html (C++) GRUMMP is another 2/3D mesh generator using linear triangular/tetrahedral elements: http://tetra.mech.ubc.ca/GRUMMP/ (C++)
Tetrahedral vs. Hexahedral Meshing for CFD | Andy Bartels | Main CFD Forum | 16 | September 20, 2019 10:06 |
'Tetrahedral meshing has failed for volume...' | Murat | FLUENT | 5 | February 19, 2011 04:22 |
Anisotropic Tetrahedral Meshing using Gridgen? | Turbomachinery | Pointwise & Gridgen | 2 | May 7, 2007 07:13 |
tetrahedral meshing in square channel | Aashutosh Magdum | FLUENT | 4 | May 28, 2005 20:27 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 11:09 |
