February 28, 2014, 06:35 |
Modelling of Cooling Tower
Ritz
Hello!
I am a final year mechanical engineering student and I am doing a project on natural draft cooling towers. My literature research leads to a finding that for an efficient heat transfer through the tower, the mass flow rate of water across the cross section of the tower needs to be varied, ie. higher water flow rate near the tower periphery, and lesser towards the middle. The heat transfer is governed by a set of partial differential equations. So, to experiment with different water flow distribution, is using a CFD software the only way, or can a manual method be of assistance? If so, will it be possible to do the modelling in a period of a month (or, two weeks more, max), given that I have no knowledge of using CFD and need to take my professor's help? |
March 30, 2014, 00:05 |
Ashutosh
Rep Power: 12 |
I suggest you try for a physical experimental model and try to vary the parameters to achieve your objective. As far as CFD is concerned, one cannot guarantee as to how much time will be required to model the problem. It depends upon the complexity of your problem.
January 12, 2016, 04:16 |
miguel pace
Rep Power: 10 |
Impact Cooling Solutions |
How to Modelling Cooling Tower using Porous Media | harkerz | FLUENT | 2 | June 6, 2017 08:31 |
Cooling tower: several aspects | letzel | OpenFOAM Running, Solving & CFD | 6 | March 15, 2014 03:07 |
Help me to simulate mixture model in cooling tower | harkerz | FLUENT | 0 | April 24, 2013 06:09 |
Cooling Tower | Roberto | FLUENT | 8 | July 22, 2009 03:16 |
Evaporation of droplets in cooling tower @cfx10-11 | Mauricio Labarca | CFX | 0 | March 28, 2008 20:02 |
