February 23, 2007, 08:22 |
Simulating smoke-rings
Has anyone simulated smoke-rings? Alternatively, if folks could direct me to useful links relating to simulation, or experimental work done in this area, I'd be most grateful.
Many thanks, desA |
February 23, 2007, 15:01 |
Re: Simulating smoke-rings
Do a quick search on vortex ring simulation, which this problem is. There are many papers out there.
Adrin |
February 23, 2007, 23:11 |
Adrin Gharakhani wrote:
Do a quick search on vortex ring simulation, which this problem is. There are many papers out there. desA's reply: Thanks so much Adrin - nice to hear from you again. I did a little searching & found some lovely pictures of natural & lab observations. Would you know offhand if the any of the papers explore the underlying physics & manage to explain the phenomena mathematically? This is where I'd like to see what they understand in terms of the physical mechanism at work. A few musings: Can this 'vortex ring' phenomenon, for instance, be linked to other observed phenomena - at say slightly higher speeds? Would/could vortex motion in any way be linked to wave phenomena? Thanks so much for your input. desA |
March 2, 2007, 15:23 |
Papers by S. Widnall should help you out with the physics of vortex ring instability, etc.
http://web.mit.edu/aeroastro/www/peo...lications.html gives a list of her publications on this topic. There are quite a number of (more recent) simulations that try to explain the process as well. Adrin |
Car park ventilation and impulse fans | guillaume | Phoenics | 9 | October 27, 2015 05:57 |
Questions about smoke modeling using CFX | rafiktharwat | CFX | 0 | March 14, 2011 11:38 |
smoke (fire simulation) | matt | Siemens | 0 | January 5, 2007 04:48 |
smoke (fire simulation) | matt | Fidelity CFD | 0 | January 5, 2007 04:47 |
smoke & screen | Marko | Main CFD Forum | 12 | May 15, 2000 11:56 |
