influence of convex or concave control volume in finite volume discretization
Old   March 23, 2014, 15:34
Question influence of convex or concave control volume in finite volume discretization
openfoammaofnepo is on a distinguished road
Dear CFD friends,
When we do the finite volume discretization, if the control volumes are polyhedral, then the feature that the control volumes are convex and concave has any influence on the finite volume discretization? In terms of the Gauss divergence method, convex control volume is not a required condition, but how it affects the discretization? Any hints? Thank you very much.
Thanks,
OFFO
openfoammaofnepo is offline   Reply With Quote
Old   March 24, 2014, 02:13
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
There are typicaly two aspects to consider (in my knowledge):
1) Geometrical algorithms. These are used to build face and volume related quantities for the FV cell. You have to be sure that these work well for non convex polyhedra. Algorithms related to point search, particle tracking, etc. might also have some requirement.
2) Accuracy for the face flux. In general, when you use a first order Taylor reconstruction and the mid-point rule for the face integrals you might end-up with a severe error for non-convex polyhedra. Consider, for example, a C-shaped 2D cell, would you expect this discretization to work well in this case? However, i suggest to look for geometric multigrid topics. That's possibly the only case where such cells might come out.
sbaffini is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
Control Volume FEM Charles Main CFD Forum 0 February 26, 1999 04:19
