Rotor Reynolds Number
Old   March 19, 2014, 12:38
Default Rotor Reynolds Number
Kishen
Kishen is on a distinguished road
Hi
I need to calculate the Reynolds number of a Rotor Blade. The freestream velocity is 30m/s but the rotor is rotating at 250rpm. In the Reynolds number equation what do I use as the Velocity and the length? Is it the overall span or the chord?
The reason I need to calculate this is to set the correct values of turbulence intensity and viscosity as my CFD solution is giving me "Turbulence Viscosity Limited on XX faces"
Thanks You
Kishen is offline   Reply With Quote
Old   March 19, 2014, 23:04
Xiaohua Li
liulangdefeng2222 is on a distinguished road
Originally Posted by Kishen View Post
Hi
Thanks You
usually about 1million, "Turbulence Viscosity Limited on XX faces",you can see the fluent help, it has explained it in detail.
liulangdefeng2222 is offline   Reply With Quote
ERROR #001100279 has occurred in subroutine ErrAction. smnaryal CFX 11 December 20, 2017 16:32
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
Stable boundaries marcoymarc CFX 33 March 13, 2013 06:39
error in parallel run immortality OpenFOAM Running, Solving & CFD 7 January 1, 2013 13:35
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
