Aerodynamics Influence Coefficents, AIC
Old   March 14, 2007, 11:04
Default Aerodynamics Influence Coefficents, AIC
Bukhari
What are these Aerodynamic Influence Coefficents and how we can get these from Unsteady pressure distribution using FFT.
Thanks
Old   March 20, 2007, 03:56
Default Re: Aerodynamics Influence Coefficents, AIC
Paolo Lampitella
Are you talking about something Aeroelastic or just Aerodynamic?
Old   March 20, 2007, 05:15
Bukhari
That's related to AeroElasticity
Old   March 20, 2007, 11:08
Luca
hi, have a look at www.aero.polimi.it/~cavagna under the publications section. Luca
Old   March 21, 2007, 05:43
Paolo Lampitella
I'm not able to go further because it's not my field. You should follow the Luca's link.
Old   March 21, 2007, 06:14
Bukhari
Thanks a lot, I will be looking on these papers.
Old   March 21, 2007, 06:16
Bukhari
Thanks,
That might help!
Old   March 21, 2007, 10:20
Peter Attar
The classic definition of aerodynamic influence coefficients is that the the A_ij component of the coefficent matrix relates the velocity potential at a point "i" to the "downwash" w at a point j(normal velocity on the wing) ie:
phi_1=A_11*w_1+A_12*w_2+A_13*w_3+..... phi_2=A_21*w_1+A_22*w_2+...
etc
you can also think of them as relating the force at point f_i to the downwash at a point j ie
f_1=B_11*w_1+B_12*w_2+B_13*w_3+..... f_2=B_21*w_1+B_22*w_2+...
the A_ij(and B_ij) are functions of Mach number and reduced frfequency.
As far as determining them from unsteady pressure measurements you would need additional data such as surface velocities I believe. A search of the literature should come up with numerous methods for approximation these coefficients numerically.
Gravity (g) Influence on Simulation Results Colin FLUENT 12 September 23, 2015 09:45
Consultant w/ Expertise in Aerodynamics & CFD Philip Sorensen CFX 4 February 27, 2007 21:12
Consultant w/ Expertise in Aerodynamics & CFD Philip Sorensen Main CFD Forum 7 February 27, 2007 16:54
Consultant w/ Expertise in Aerodynamics & CFD Philip Sorensen FLUENT 0 February 19, 2007 13:45
AIC (Back to the Past) Aldrin Wong Main CFD Forum 1 March 12, 1999 06:21
