Water Boiling Question - Closed Cylinder
Old   March 25, 2014, 12:28
Default Water Boiling Question - Closed Cylinder
shreesha87 is on a distinguished road
Hello everyone
I have a general question about thermodynamics/fluids. I did not know which forum should I post this so selected this forum.
Assume I have a perfectly sealed cylinder filled with water completely (no gaps whatsoever). I heat the cylinder from the outside
to 100 degrees C. So will the water boil?
Shree
shreesha87 is offline   Reply With Quote
Old   March 26, 2014, 04:13
Phoevos
fivos is on a distinguished road
Your question is not correctly defined. First of all you should define the operating pressure (or lets say the initial pressure) of your water mass.
Assuming you begin with water at atmospheric conditions (p=1bar) then still you need more data about the exact heat you provided. The reason is that at 100C you may have saturated water, saturated steam, or steam and water mixture. You can also see here:
http://en.wikipedia.org/wiki/File:TS...dampf_engl.png
Here you can see the T-s diagram for water. For pressure of 1bar there are infinite possible conditions corresponding to T=100C, all under the saturation curve (the red one).
So, in order to get a definite answer it is essential to know the exact heat provided, through which you can find the enthalpic rise (see http://www.engineeringtoolbox.com/mo...ter-d_308.html). By having specified enthalpy and pressure you have defined a single point.
Note that in reality things are not simple because by heating water, it will expand. Since you perfectly constrain it, heating will pressurize it above the initial pressure. Thus, I think, that is safe to assume that at 100C the water would still be subcooled water, since its pressure will be higher than 1bar.
fivos is offline   Reply With Quote
water boiling, evaporation, condensation Hao FLUENT 14 April 21, 2017 13:08
Boiling water in a horizonatal channel Ahmad Al-Zoubi Siemens 2 February 8, 2011 19:29
A question (water droplet) john Main CFD Forum 1 October 25, 2008 03:42
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
closed casing with fan and water Tom Main CFD Forum 0 August 27, 1999 01:16
