DES, LES and DNS applications
Old   May 3, 2007, 05:21
Default DES, LES and DNS applications
James M
Hello everyone,
I'm an undergrad university student currently researching for an essay on CFD turbulence models and applications and I would like to know what are the main differences between the three methods (DNS, DES and LES) and also what domains do they apply to (i.e. automotive, marine, gas kinetic etc...)?
Any Help will be greatly appreciated. Thank you very much!
James M
Old   May 3, 2007, 05:44
Default Re: DES, LES and DNS applications
Dominic
http://www.cfd-online.com/Wiki/Turbulence_modeling
Old   May 4, 2007, 04:51
James M
thanks for the link, very helpful indeed. However, it does not indicate what fields do they apply to. Are LES and DES more used in flow over airfoil and general aerospace and automotive industry, or do they apply to other fields like marine, physics, combustion etc...?
Thanks
Old   May 7, 2007, 13:14
Lionel Larchevêque
LES is now commonly encountered in combustion, at least in laboratory, mainly because it give access to the (coarse) structure of the flame front, therefore making the combustion modeling easier (less assumptions based on pdf, ...). It is also used in astrophysics and I remember a seminar talk by Oran dealing with some marine problems.
DES studies are more focused on aerospace and automotive topics presumably because: - it's a rather young turbulent modeling (less than 10 years) coming from the aerospace field: it needs time to widespread - it is well-suited for massively separated flow commonly encountered in these industries.
It is worth noting that LES and, to some extent, DES, are not that common in industry because of the huge computational resources that are required. Moreover very well-trained scientists are still required to run them adequately (they are far from being fire-and-forget methods yet).
Regards
Lionel
Old   May 8, 2007, 04:58
James M
Thank you for your precious comments Lionel. If you can indicate me where can I learn more about the seminar talk that would be nice.
Regards,
James M
Mesh size for DNS and LES Glenn Horrocks Main CFD Forum 45 May 25, 2020 15:43
doubt about DNS and LES of combustion chinthakindi Main CFD Forum 5 August 17, 2013 11:56
DNS and LES resolution Larsen Main CFD Forum 0 November 25, 2010 18:10
Need help for DNS and LES methods Paul Main CFD Forum 1 August 12, 2003 07:22
Laminar solver? LES? or DNS? Ray Main CFD Forum 5 March 19, 2003 10:19
