Governing equations to model fluid inside a tank |
April 24, 2007, 06:32 |
Could somebody suggest the mathematical model (set of equations) to depict the solution profile of liquid under strong perturbation at the bottom of a tank? If some references or software for the same is available please let me know. Any information for the same will be a great help for me.
April 24, 2007, 11:03 |
Re: Governing equations to model fluid inside a ta
This problem has some approximate analytical solutions.You can do a normal mode analysis to obtain the solution.Have a look at any of the stability theory books.(Reid or Chandrasekhar)
April 24, 2007, 23:32 |
Thank you Harish for the information. I think, probably I could not made the problem clear in my previous post. I am looking for the governing partial differential equations which model the fluid behavior under strong perturbation at the bottom of the tank. Also If possible, the analytical solution of it. Please suggest some references to me in this regard?
Ritesh.. |
April 25, 2007, 16:37 |
The governing equations are the incompressible N-S equations assuming the fluid can be treated as incompressible.The analytical solution may not available directly depending on the kind of geometry and other parameters.But can be obtained using normal mode analysis given in books on hydrodynamic stability.Most of the papers in this field might be found before 1960.
April 25, 2007, 23:51 |
Thanx for your suggestion.
regards Ritesh |
fluid movement with friction inside a pipe | hamid1 | FLUENT | 3 | September 15, 2011 11:30 |
error using combination of step function | xujjun | CFX | 1 | January 15, 2008 16:46 |
Water vapour condensation in CFX-5.7.1 | hdj | CFX | 1 | November 27, 2005 07:15 |
CFD analysis of Fluid Flow over a Weir in a Tank. | ronan moore | Main CFD Forum | 2 | February 4, 2005 07:15 |
