CFD over rectangular wing with multi winglets |
April 17, 2014, 15:17 |
Geetesh Waghela
Rep Power: 12 |
hey, i am simulating flow over a rectangular wing of semi span 300mm and chord of 75mm at the root with taper ratio as 1.
i want to validate with the wind tunnel results. i have used naca 0015 airfoil. i have used spalart-allamaras turbulence model and inlet velocity as 20m/s, outlet gauge pressure as 0. rest everything is set as wall. i am getting floating point error mostly and when i reduced reference values by half, my continuity equation is diverging in range on 1e+05. what can i do now to converge the solution?? i would like to proceed for multi winglets after i get this right. |
April 23, 2014, 05:49 |
venki
Rep Power: 14 |
wch solver your using ?
April 23, 2014, 14:34 |
Geetesh Waghela
Rep Power: 12 |
i am using ansys fluent 14.5
i tried using k omega sst model also for solving but the results i am getting are varying from experimental data. since the domain is restricted to a particular size, will it be accurate to use spalart allamaras model? |
divergence detected, reversed flow, spalart allmaras, wing |
Multi element wing CFD | glp1e11 | ANSYS | 0 | January 21, 2014 14:49 |
CFD of Wing on fixed Angle of Attack | samuelcarlo | CFX | 7 | August 4, 2013 07:09 |
CFD of conventional wing with a winglet? | mimi | Main CFD Forum | 0 | December 7, 2006 09:52 |
ASME CFD Symposium - Call for Papers | Chris R. Kleijn | Main CFD Forum | 0 | September 8, 1998 08:19 |
ASME CFD Symposium - Call for Papers | Chris R. Kleijn | Main CFD Forum | 0 | September 3, 1998 08:45 |
