Re: turbulent mixing of two fluids
Old   October 11, 1999, 06:38
Default Re: turbulent mixing of two fluids
Jin Wook LEE
I do not think two fluid model is required because of different molecular viscosity. I think that it is enough to model the viscosity of mixture as a function of the mass(or mole) fraction of each fluid. In addition, I am quitely sure that molecular viscosity has not so significant effect on the flow field for the turbulent flow, as John said.
Sincerely, Jinwook
Turbulent eddy diffusivity for mixing?? Ray Main CFD Forum 3 November 5, 2020 11:57
two mixing compresible fluids solver ziemowitzima OpenFOAM Running, Solving & CFD 27 August 13, 2020 12:40
Turbulent flow of two incompressible fluids with the same physical properties ArneBab OpenFOAM Running, Solving & CFD 3 January 5, 2010 05:48
FIDAP-Properties Definition in Fluids Mixing Area Q. Hao FLUENT 0 February 17, 2005 12:00
turbulent mixing of two fluids ulrich bieder Main CFD Forum 2 October 9, 1999 16:15
