Reimann problem
Old   May 24, 2007, 20:34
Default Reimann problem
Shuo
What's the difference between the Riemann problem and the shock tube?
Old   May 25, 2007, 05:13
Default Re: Reimann problem
Tom
The Riemann problem is a method and the shock tube is an example of the method.
Old   May 25, 2007, 13:34
jinwon
I guess you have confusions about the concept of the Riemann problem.
Riemann problem is a problem containing one single wave. That is,
u(x,t=0)=uL for x <x0
uR for x >x0 Like above, the problem is spatially divided by two region but constant. If it is not constant(i.e. uL(x),uR(x)), it is called the Generalized Riemann problem.
The shock tube problem is a very famous example used to simulate such a riemann problem.
The reason you confused may be the difference between the exact solution and the numerical solution of the Riemann problem. There are a number of books available on this issue. For example, computational gasdynamics written by Culbert B. Laney.
Good luck
Old   May 25, 2007, 14:51
Remi
is there any other example of the Riemann problem ?
Old   May 26, 2007, 10:09
Tom
A dam breaking in shallow water is one. Any problem governed by a hyperbolic equation has a Riemann problem (look up the theory of Riemann invariants in a book on pdes).
Old   May 28, 2007, 15:44
Remi
Do you think someone can see it in two-phase flows ? any advice will be very much appreciated.
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Problem in implementing cht tilek CFX 3 May 8, 2011 08:39
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
