Same model and settings, but different simulation results? |
May 24, 2014, 06:16 |
Nanette
My project is to simulate the internal airflow of a sailplane at wind tunnel conditions using Star CCM+. I used the basics of a tutorial video I found on youtube as my "recipe" and it worked perfectly. When I finished the model and started the simulation all the residuals fluctuated badly and didn't seem to want to stabilize after 600 iterations. I created a new simulation using the same model and followed the exact same "recipe" as the previous one, and the residuals started stabilizing after 200 iterations. I asked my Professor about it and he said that it had happened to him a lot as well. How do I know that the simulation is safe to use if the same thing shows two clearly different results? Settings used: Mesh: Surface wrapper, surface remesher, trimmer and prism layer mesher. Physics: Steady, gas, segregated flow, constant density, turbulent, K-Omega turbulance, three dimensional. Can one of these settings change the outcome of a simulation even if everything else is the same? |
May 24, 2014, 12:29 |
#2 | |
Shawn
Rep Power: 14 |
If you are telling what you were doing, and they are truth, you had better tell the New York Times that 'Star CCM+ is cheating everyone of us'. I suggest you check it again. Good luck, Shawn |
Importing Rhinoceros 3d model to SolidWorks | george85 | FloEFD, FloWorks & FloTHERM | 21 | March 5, 2014 05:19 |
SST Model for Low Re ... some minor settings | mrenergy | FLUENT | 7 | January 18, 2013 21:13 |
Model settings for lower Re flow? | Dale MC | FLUENT | 2 | April 15, 2009 07:53 |
Aabout settings of contamination model | Li | CFX | 1 | June 22, 2007 08:28 |
HP Turbine Flow simulation Solver settings | Puneet | FLUENT | 1 | August 10, 2003 05:00 |
