May 30, 2007, 06:37 |
data exchange between two binary codes
Dear Friends,
I like to execute two binary codes simulteneously and exchange some data between them dynamically, they write exchanged data on disk. my problem is tunig of codes so thay they access to disk is a suitable time, (e.g. they can paused by reading a parameter from command line and after entering parameter they continue, but performing this by hand is tedious) do you know a suitable (simple) software/way for this purpose? |
May 30, 2007, 10:03 |
Re: data exchange between two binary codes
this looks similar to parallel possessing (check PVM and how the slaves communicate).
S.K |
May 30, 2007, 12:22 |
note that i deal with two separated binary package that i don't have access to their source code.
May 31, 2007, 01:34 |
Hello rt,
the normal way to run several binary packages with data exchange is to control the process chain with some shell scripts. Regards, Markus |
May 31, 2007, 05:46 |
Are you looking for timestep exchanges (i.e. co-simulation) or does one code finish before the next one starts? If it's timestep coupling, you'll probably need to write some blocking code in whatever subroutine mechanisms you are given. Otherwise, script it. I suppose it could be possible to script the codes to run one step at a time each??
May 31, 2007, 08:22 |
Thanks Steve, as u and Markus stated, using a shell scripte seems to be my only solution, so i will try it.
June 16, 2007, 05:09 |
to know about data exchange between two or more binary codes
【Help】"Error: Update_Time_Level: invalid data" | Chen | FLUENT | 2 | August 24, 2014 08:51 |
How to exchange the data in DEM/Fluent using UDF | Xiaoyong Lu | Fluent UDF and Scheme Programming | 1 | May 30, 2012 00:52 |
export data at nodes | Meenu | FLUENT | 1 | December 30, 2011 02:24 |
data exchange between two binary code | rt | Main CFD Forum | 0 | May 30, 2007 06:37 |
Binary files stored by Fluent | Jackson | FLUENT | 1 | April 2, 2000 22:58 |
