From AutoCad to CFD
Old   June 7, 2007, 08:53
Default From AutoCad to CFD
Yannis
Hello guys...i am a student in a Univeristy of Greece but that s not the case.. Actually i m going to use CFD for my thesis..so i have a kind of problem..i dont know if it s possible to transfer models from AutoCad to CFD..And if it is , i would be grateful if sb could explain that to me..
Thx in advance...
Old   June 7, 2007, 11:19
Default Re: From AutoCad to CFD
Yannis
I m Talking about CFDRS....
Old   June 7, 2007, 12:17
john.deas@gmail.com
which CFD package do you intend to use ?
Old   June 7, 2007, 13:07
Ahmed
AutoCad can export in iges file format which can be read by a lot of CFD programmes
Old   June 7, 2007, 20:26
Default ABOUT CFDRS
Yannis
I m talking about CFDRS..
I have AutoCad 2007 which as far as i can see,because i m not an expert,it exports in *stl , *eps , *dxx , *dwg , *dwf , *wmf , *sat and *bmp file formats...So what about iges files??
Old   June 7, 2007, 22:36
Default Re: ABOUT CFDRS
Ahmed
OK, sounds a bit weired that Autocad does not export iges files, your AutoCad must be A special version, any way if you can export in STL, then use it. I am not familiar with that CFD programme But you can check the formats that can be imported and check if any is produced by your AutoCad Good Luck
Old   June 8, 2007, 04:26
Yannis
Thx anyway..
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 19, 2015 23:40
CFD for fans & blower housings David Carroll Main CFD Forum 8 August 24, 2000 17:25
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 August 21, 2000 04:49
PC vs. Workstation Tim Franke Main CFD Forum 5 September 29, 1999 15:01
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
