June 21, 2007, 09:56 |
DES and LES meshing: tips and advice?
I'd like to enquire if any of you can advise me on a tutorial or guidelines on grid generation for DES and LES problems. I understand the meshing is different than RANS, more complex and delicate so I turn to all the great scientists and engineers of the forum for some help! Thank you in advance. James |
June 25, 2007, 03:57 |
Re: DES and LES meshing: tips and advice?
Do not mesh! Just generate a continuous substrate of solids/fluids in your 'domain'. Discretized mesh has to be eilminated. Continuum 'mesh' is the way to do it.
p/s: dont take this too seriously |
June 25, 2007, 10:23 |
I see... Is there any particular reason as to why discretized mesh is not welcome? What about the boundary layer?
Thanks |
June 27, 2007, 13:43 |
Do a RANS simulation first. Extract the integral scale and prepare your LES mesh such that your mesh size is about 1/10 of this scale. As for boundaries, refine your mesh to make y+ of order unity close to the wall (LES).
DES and LES meshing: tips and advice? | James M | FLUENT | 3 | June 24, 2007 20:22 |
