June 29, 2007, 08:35 |
Combustion methane-air
Hi !
I'm trying to compute a methane-air combustion of a premixed system. Methane and air are introduced in a small tube, conneted to a combustion chamber at 0.5 Mpa, by a swirl injector. My main parameters are : ---SOLVER Pressure based, Axisymmetric Swirl, steady. ---SPECIES MODEL Species transport, Volumetric Reaction, Finite-Rate/eddy-Dissipation, Mixture = methane-air ---Operating Conditions Op. pressure = 500 000 Mpa ---Boundary Conditions Inlet : velocity inlet. Outlet : pressure outlet (=0 Pa) ---factors turb. kinetic energy 0.04455. turb diss. rate 0.506 The problem is that my results are not the same as the ones presented in a paper with the same computation, concerning pressure especially. First of all, is there any parameter that seems not correct ? Thanks a lot for your help |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
Hydrogen Air combustion in a combustion chamber | popi | CFX | 7 | July 11, 2007 18:40 |
Lean swirled premixed combustion methane air | bisounours | FLUENT | 0 | July 4, 2007 06:52 |
How to model combustion with only methane stream? | ligang zheng | FLUENT | 2 | May 1, 2007 09:16 |
Methane Combustion | Lars | FLUENT | 4 | March 5, 2003 08:24 |
