periodic and cyclic boundary conditions
Old   June 29, 2007, 03:56
Default periodic and cyclic boundary conditions
Hadi
hello, Could anyone tell me what is the difference between cyclic and periodic boundary conditions? Thanks in advance Regards Hadi
Old   June 29, 2007, 05:46
Default Re: periodic and cyclic boundary conditions
Praveen. C
Think of an O-grid in 2-D. There is one set of grid-lines which are closed; the first and last point on these lines are the same. You need cyclic conditions; its not really a boundary. For example if the grid index that goes around is i, and it ranges from 1 to imax, then u(1,j) = u(imax,j) for all j. Also in a finite difference scheme, if you need u(i-1,j) for i=1, then it will be u(imax-1,j). You get the idea.
A function is periodic if
u(x+L) = u(x)
Note that it is defined in all of R, the real number set. But it is enough to compute it in say [0,L]. When you apply some finite difference or your favourite scheme, you may need values outside [0,L]. Then you make use of the periodic condition to get these values.
Old   June 29, 2007, 07:19
Hadi
Thank you praveen for the explanation Could you please tell me the definition of these two boundary conditions in the case of LES turbulent channel flow? regards Hadi
[Commercial meshers] Face ordering problem for nonrectangular cyclic boundary conditions cfdmarkus OpenFOAM Meshing & Mesh Conversion 3 August 17, 2011 15:07
Boundary conditions between blocks maxNeptune OpenFOAM 0 March 19, 2011 10:16
Cyclic Boundary Condition/Periodic boundary deji OpenFOAM 0 November 2, 2009 12:53
Possible problem in cyclic boundary conditions in parallel cases alberto OpenFOAM Bugs 3 June 10, 2009 11:22
Channel flow with cyclic boundary conditions nzy102 OpenFOAM Running, Solving & CFD 0 April 19, 2007 16:13
