How to simulate a pipe flow with a recirculating loop?
1 Attachment(s)
Hi everyone,
Could anyone give me some instruction on simulation of a pipe flow (the main flow) with a recirculating loop (secondary flow)? The physical problem is described in the attached figure. The oil-water mixture flows from the left to the right hand. It is sucked by a pump (at a given rate downstream) and is re-injected to the front through a number of small jets. To me, there are two inlets and outlets. Is it possible to simulate this process using FLUENT? Any instructions are appreciated! Regards, Jing |
