July 6, 2014, 18:14 |
What is the smallest mesh I can have?
musaddeque hossein
Rep Power: 18 |
Dear all:
I have a very small tank (0.1mx0.510m). Mesh size is 50X200. Water depth is 0.021m. When I apply a sinusoidal displacement to it, I see wave breaking, but the graphics does not seem right. Can anyone tell me if this is because of the tiny mesh size? I am using paraview 4.1.0 and openfoam 2.2.1. I have attached the paraview image. The input waveform is also attached. Thankyou, Musa |
July 7, 2014, 04:42 |
Siamak Gharahjeh
Rep Power: 13 |
I am strongly doubtful that a small mesh is posing a problem, the smaller the mesh the safer the solution. Even from a certain point on, solution should be independent of mesh size.
If you like to know the the smallest mesh you can have, it is found in a trial and error procedure. That is, your y+ should be at most 2 next to the wall for correct shear stress calculation (running the simulation and checking the y+, changing the mesh and running it again). |
July 7, 2014, 07:31 |
#3 | |
musaddeque hossein
Rep Power: 18 |
July 7, 2014, 08:08 |
Siamak Gharahjeh
Rep Power: 13 |
Anytime.
No, the point is to stay in the viscus sub-layer which happens at y+<5 (y+=yu*/viscosity), when I say y+ at most 2. This is because wall shear stress is calculated from laminar shear stress formula ,Wall shear stress= Mu*du/dy (Mu laminar viscosity). However, 5 is too big for y+, therefore they say that 2 is better. You will need to calculate y+ at the end of a solution convergence for a given mesh configuration. That is, u* which is an always constant value beside the wall and y value which points to the location of first grid point next to the wall to be able to calculate y+=yu*/viscosity I should actually have asked whether you are developing a code by yourself. Because if you make use of commercial codes, I think they use wall functions. In that case you have nothing to worry about. |
July 7, 2014, 09:15 |
musaddeque hossein
Rep Power: 18 |
I am using OpenFoam. Your discussion was most insightful -- I should have done some diligence before posing this question. So thankyou again.
shallow tank, solshingtank2d, tiny mesh size |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[snappyHexMesh] snappyHexMesh & Mesh around a missile | sasanghomi | OpenFOAM Meshing & Mesh Conversion | 2 | October 15, 2014 19:54 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 13:40 |
Smallest mesh size | cfd_newbie | FLUENT | 2 | December 5, 2008 05:29 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 12:21 |
