July 28, 2007, 19:47 |
supersonic flow past flat plate
Hi
I am simulating it by solving the conservation form of the Navier-Stokes equations using MacCormick's method. I am solving it at Ma 4, Re 700. The velocity profile looked reasonable (compared with vanDriest) but the pressure and density profile had sharp oscillations across the boundary layer(BL). The temperatue profile was smooth. Is there any way I can minimise the oscillations(artificial viscosity?). ALso for the initial conditions, I had to use a assume a linear BL velocity profile over an equivalent subsonic Blasius flow. If I assumed uniform velocity everywhere except at the plate, the solution blows up immediately. Is it because of the huge velocity difference at the surface nodes? For hypersonic flows Ma > 6 the solution always blow up. Cheers Shuo |
compressible laminar flow over flat plate | varunjain89 | Main CFD Forum | 19 | April 18, 2019 06:07 |
Experimental paper for flow over flat plate | Sid | Main CFD Forum | 3 | October 8, 2008 11:45 |
Flow over a flat plate & Flow over a cylinder | cfdxue | Main CFD Forum | 0 | November 26, 2007 23:26 |
BIg BIg Problems....SUPERSONIC FLOW OVER A FLAT PL | edison | Main CFD Forum | 7 | October 11, 2005 09:34 |
results for flow past flat plate normal to flow | lisa | Main CFD Forum | 2 | August 30, 2005 16:36 |
