August 16, 2007, 21:39 |
Unit of Density Gradient
Dear friends,
I got the Density Gradient in Tecplot360. Could you tell me the Unit of Density Gradient? Thank you in advance. Eric |
August 17, 2007, 00:47 |
Re: Unit of Density Gradient
It should depend on the units of your density field and mesh coordinates.
August 17, 2007, 01:39 |
Thank you.
I use the Unit kg/m^3 for the density, and Cartesian coordinate system. |
August 19, 2007, 21:23 |
Help me please.
August 20, 2007, 09:33 |
The gradient dimension is going to be (units of density)/(units of length). As nobody said - it depends on the units you are using. A cartesian grid system could have length units of meters, inches or parsecs. You should be able to figure this out.
Using Density Gradient C_R_G(c,t), Pressure Based Solver | Anirudh_Deodhar | Fluent UDF and Scheme Programming | 1 | October 25, 2013 05:43 |
salinity solar gradient pond (different density) | prodriguez7 | FLUENT | 0 | October 6, 2010 05:00 |
How to obtain density gradient? | connyg | FLUENT | 0 | December 18, 2006 11:32 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 08:23 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
