Post-Processing CFD Boundary Layer Information
Old   August 22, 2007, 09:41
Default Post-Processing CFD Boundary Layer Information
Glenn
Colleagues, I have a 3-D, compressible flow CFD solution with a nicely refined wall mesh (Y+<1, multiple mesh in near-wall regions, etc.). I would like to post-process the solution across the wall boundary layer at varisou locations and cross plot the results to compare to the universal velocity distributions laws. My dilema is that the freestream flow has a continually varying velocity characteristic and I am not sure how to accurately determine the "edge of boundary layer". (Simple rules like Vedge=0.99*Vfreestream are not applicable, since Vfreestream varies continually). How can I determine the "edge of boundary layer" location accurately from a general 3-D result, which tells me flow variables as a function of normal distance from a wall point? Any insights into this is appreciated.
Old   August 22, 2007, 10:38
Default Re: Post-Processing CFD Boundary Layer Information
otd
You might want to try the 'displacement' boundary layer, which is a lot less arbitrary than the usual '% of free stream.'
I just put 'displacement boundary layer' into Google and got 1,880,000 'hits' including some current text books.
Good luck!
How to set boundary layer of a moving body in GAMBIT to a mesh zone for dynamic mesh tomyangbath FLUENT 18 October 12, 2016 06:57
[snappyHexMesh] snappy hangs while layer generation bastil OpenFOAM Meshing & Mesh Conversion 3 October 29, 2010 07:19
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 13:47
Boundary Layer Meshing of a nosecone Chris FLUENT 1 March 15, 2005 12:42
post processing in CFD MANISH BHARGAVA Main CFD Forum 0 October 17, 1998 20:51
