August 12, 2014, 09:40 |
CFD beginner
Abhinav Pandey
Rep Power: 11 |
Hey all!
I have just started learning CFD, some 2 months back. And I need some guidance from you. There is this project I am working on, which involves fsi analysis of flapping wings. Now, I know this might be difficult for a beginner like me, but I am willing to devote whatever time I have into learning this. Till now I have gone through this book-> Intro to CFD by John Anderson. It really helped me in grasping the basics, tried some random analysis using the Ansys workbench(fluent),which didn't help much, and right now learning ICEM CFD( trying to be good at meshing). Also I am doing my research work on flapping flight simultaneously. How should I proceed exactly, like which meshing softwares and solvers should I choose ? Can you suggest me some books which can help me learning fsi? Thanks |
August 13, 2014, 13:11 |
Abhinav Pandey
Rep Power: 11 |
someone please reply!
August 14, 2014, 10:07 |
Rep Power: 17 |
Hi, It sounds interesting to me.
You can contact me on patel.mehulkumar.l@gmail.com |
August 16, 2014, 22:24 |
Well, You are working on a big target...
a) Do you want to write your own code for Flapping Wing project or you want to use existing codes. Either ways you need to understand how the code works and what basic equations that go in and what methods you will be using to solve the basic governing equations. ALE, Moving meshes, Mesh less methods, particle based methods are few buzz words in this area... There is lot to explain in this regard ... a simple post like this wouldn't be sufficient enough. If you have specific question in mind, if you can post it we can try to answer if it is in our range. Regards |
CFD Code + partner required + beginner | amol palekar | Main CFD Forum | 1 | July 18, 2004 15:32 |
Beginner - Has Phoenics CFD software for mixing? | mixerer | Phoenics | 2 | July 10, 2002 10:54 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 21:10 |
ASME CFD Symposium, Atlanta, July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | August 21, 2000 04:49 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
