August 12, 2014, 12:44 |
matlab code for channel flow
Rep Power: 11 |
hey all
i'm working on matlab code for instationary channel flow with given boundary condition: Inflow: u(t=0) = 0, v(t=0)=0 and P= f(t) > 1 Walls: u = 0, v = 0 Ouflow: free outflow dudx = 0, dvdx = 0 and P = 1 at the end i need the velocity of u. i failed to modify the programm "MIT18086" because of the given boundary pressure. or for the simplicity i could assume that the pressure is linear decreasing from in- to outflow and use the equation du/dx+dv/dy=0 to calculate v. and then insert to the navierstokes and try to calculate that but then i have a problem with v*du/dx and u*du/dy anyone ideas or solution for this problem? thanks Last edited by mrxD; August 13, 2014 at 04:13. |
October 5, 2015, 17:07 |
#2 | |
mechiebud
Rep Power: 11 |
October 5, 2015, 22:05 |
Rep Power: 12 |
October 6, 2015, 02:16 |
mechiebud
Rep Power: 11 |
yes I know that. But since I missed my classes I am unable to start this one. The lid driven cavity and alternate directional implicit problem I solved myself.
mechiebud
Rep Power: 11 |
October 6, 2015, 06:35 |
#6 | ||
Kaya Onur Dag
Rep Power: 13 |
if you guys get stuck somewhere specific on the development satge, I think I can help but I am not sure if I got your problem. |
October 8, 2015, 02:29 |
mechiebud
Rep Power: 11 |
Thanks kaya. I am doing a 2D laminar flow on a channel using SMAC. I am unable o initialize the pressure.Could you please guide me through that.
October 8, 2015, 05:20 |
Kaya Onur Dag
Rep Power: 13 |
Sorry I can't help you with SMAC since I never worked with that.
I think you're not using MIT18086? According to its manual, it doesn't use SMAC but a projection method for pressure coupling. I think it solves the momentum equations and finds an intermediate velocity ( which doesn't satisfy continuity at this stage). And with a pressure correction ( which is found by taking divergence of this intermediate velocity --> poisson equation) the intermediate velocity is updated to the u^(t+1). I saw that they put the matlab code in the course's webpage. |
October 8, 2015, 05:25 |
#9 |
Kaya Onur Dag
Rep Power: 13 |
see the page 4
http://math.mit.edu/~gs/cse/codes/mi...vierstokes.pdf |
October 8, 2015, 05:34 |
#10 |
mechiebud
Rep Power: 11 |
Thanks a lot for your response. Yes I have seen that code but I need to do it using SMAC. Since I am new at CFD I am facing certain certain challenges. Anyways I'll try to put more effort.Thanks again..
October 13, 2015, 16:41 |
#11 |
mechiebud
Rep Power: 11 |
Hi Kaya, Could you please give e some idea regarding the boundary conditions. Like what pressure and velocity boundary conditions should I use?
October 13, 2015, 17:43 |
#12 |
Kaya Onur Dag
Rep Power: 13 |
maybe no slip at the walls with neumann pressure and periodic at the inlet outlet of the channel ?
October 14, 2015, 16:38 |
#13 |
mechiebud
Rep Power: 11 |
In periodic boundary what initial values of u,v and p should I give at the left and right boundaries to initiate my simulation?
October 14, 2015, 17:24 |
#14 |
Kaya Onur Dag
Rep Power: 13 |
you can initialize your velo. field with analytical poiseuille flow solution which you can find somewhere in the middle of Frank white's text book. should be located on the top of a left page .. and then you can specify a constant pressure derivative
March 29, 2020, 19:55 |
#15 |
Shafee
Were you successful in changing the boundary conditions to achieve chanel flow
Matlab code for pipe flow | cici | Main CFD Forum | 72 | May 12, 2017 18:05 |
Couette Flow in Matlab using Pressure Correction Method | mulchah | Main CFD Forum | 4 | February 25, 2014 05:41 |
Can anyone help locating an error in my 2-D MATLAB SIMPLE code? | Hoggs17 | Main CFD Forum | 7 | July 9, 2013 03:02 |
Give me some advice CFD in Fortran code or Matlab code. | tringuyenttt | Main CFD Forum | 4 | May 29, 2013 08:32 |
What is the Better Way to Do CFD? | John C. Chien | Main CFD Forum | 54 | April 23, 2001 08:10 |
