Recommend more accurate temporal scheme in SIMPLE |
September 13, 2007, 10:23 |
Usually the time discretation scheme in SIMPLE-like algorithms is the first-order implicit Euler method.
Could you recommend some time discretation schemes with the second or higher-order accuracy that can be used in SIMPLE-like algorithms? Thanks! |
September 13, 2007, 11:25 |
Re: Recommend more accurate temporal scheme in SIM
STAR-CD uses Crank-Nicholson with SIMPLE for second order time accuracy.
September 13, 2007, 23:54 |
I have seen two schemes with high-order accuracy in SIMPLE, the Crank-Nicholson, which you have refered to, and three time level method.
Could some more schemes be introduced except the two mentioned above? Thanks! |
Implementation of QUICK scheme | Romuald Skoda | Main CFD Forum | 11 | November 6, 2017 22:20 |
AUSM scheme ? Central Scheme | boling | Main CFD Forum | 7 | January 7, 2016 03:41 |
Godunov scheme | Peter | Main CFD Forum | 6 | November 27, 2009 11:51 |
An intresting observation about SIMPLE Scheme | Abhijit Tilak | Main CFD Forum | 12 | March 14, 2003 12:48 |
Block correction scheme in SIMPLE | Chuck Leakeas | Main CFD Forum | 0 | November 20, 1998 13:51 |
