October 20, 1999, 00:20 |
gridding
Dear friends, I am trying to solve a problem of transient 3D heat conduction with heat source in cylindrical coordinates. However the system under consideration is composed of a cylinder and inside this cylinder a cube exist. This cube has a thermal propeties of course different from that of the outer cylinder. I used in the discertization of the equation a finite differences scheme. Supposing the real cube as a cylinder i got very good results. However i cannot succeed to solve the real system. Is it possible to sole such a problem. If yes what kind of modification I have to do in order to solve it. Thank you in advance for the precious time you deserve to my question. Respectfully yours Cherif
[ICEM] C Gridding and removing the triangular blocks | brissyben | ANSYS Meshing & Geometry | 8 | June 4, 2009 11:13 |
how to locate particle under a complex gridding | harry | Main CFD Forum | 0 | August 17, 2005 09:27 |
Gridding a in and around a pipe dipped into fluid | A Krishnan | Main CFD Forum | 0 | February 20, 2005 17:21 |
Gridding and geometry | muslikhin hidayat | CFX | 2 | December 6, 2000 04:04 |
Gridding | Damian Va | Main CFD Forum | 6 | August 8, 2000 11:31 |
